I have a complete holesaw set, works well enough for cutting holes, but the discs are usually a pain getting out. I don't need any holes cut just now, but could use a batch of discs. I've seen the rapid eject holesaws, never tried one, but don't want to buy one.
I'm wondering if there is some way to convert a standard holesaw so I can get the disc out quickly, and easily. I've been googling, and found zip.
The only two things I have been able to think of so far are:
1. Put a stiff spring and metal plate inside one, so the spring pushes the disc out, or at least far enough to pull it out.
2. Cut a few slots in the side of a holesaw, so I could at least stick in a small screwdriver or such in to pull down the disc.
Anyone got anything that works?
