1 - 12 of 12 Posts
Hey Guys
Just bought a Sears RAS model 113.23100 saw from a guy at work. Still looks new, little bit of rust, but nothing that can't be taken care of. Had a Sears dado blade on it, still looks good also. paid 75.00 good deal?
John
I used to have one, my good friend nicknamed it "the widowmaker" after using it a time or two and learning of its propensity to kick back given any excuse at all. I still remember reading the manual and seeing a warning never to cut anything with your arms crossed over one another. Good advice!!! Maybe it's not too late to get your money back. . .
jbi, Check with Sears recall and see it that model has any recalls for the motor, leaf guard and the like.
I had my first Sears RAS in the early 70s and learned how to make cabinets with a skill saw and the RAS. Yes I did rip many a sheet good and never had a problem. Once I did move up to a Delta turret style RAS and learned the major diffence in how heavy all that cast made on the Delta. I gave my Sears RAS away to a fellow cabinet maker.
Would not be without a RAS in my shop...
Discussion Starter · #6 ·
Yeah, I thought so too. I did carpentry work for a while, framing, finish. I had one and loved it! Did more trim cutting with it than with my chop saw! When he showed it to me, I thought he would want more for it, but when he said 75.00 we loaded it up right then.
HI jbishop
You got a great deal :)
Here's one more thing you can do with it that most don't think about .:)
It's pin router/great way to mill off stock for a sign/planer/etc.with just a shop made bracket ..
http://www.routerforums.com/28958-post6.html
Lee also has one that hangs off the saw blade end, a factory made one..
HI jbishop
Here's some snapshots of what you can also do with the RAS...
I made the router bracket with some A325 flat washers and bit of welding and some grinding and you can have one too..
It can be used for a over head pin router, putting in slots on a angle many,many things like planing down some stock,hogging out the background for a sign,etc.
Premium Member
Retired since June 2000
I'm not familiar with the machine you bought, but it sounds a great buy to me, I'm sure many members would be happy to give you a profit. I've had radial arm saws for over thirty years, my present one, a DeWalt, the same as Bj's and I could not live without it. It's true what they say about RAS's, "your imagination is the only limiting factor as to what can be done on one" so I suggest you find a book on using this fabulous machine.
Most importantly, when ripping, the riving knife and hold down MUST be in place the latter because they up-cut when ripping.
HI jbishop
I did add a snapshot of the guide pins, that I forgot to put in the 1st post,it's a must have item if you want to use the RAS saw as over head pin router :) I just about always us 1/4" thick templates made out of MDF :)
1 - 12 of 12 Posts
