Yup, I have one, but it's the 12 inch model. It has variable speed you set with a lever and will drill through something pretty thick.
https://www.amazon.com/WEN-4214-12-...pID=41g0CK2hh-L&preST=_SY300_QL70_&dpSrc=srch
It was about $220 on sale. Given tight budgets, I'd go for a minimum of 10 inches, but it doesn't have the lever to set speed, it requires rerouting belts and switching pullys. Not hard, but not easy either. The 10 inch model also has a much shorter post, which can affect how deep it is possible to drill.
The machine, however, has been excellent. The 12 inch is identical to the Jet DP, down to casting marks, but sells for much less. Search to see if you can find the lowest price. I got mine through WallMart so there was no delivery charge.
Have you found the woodworkers in your congregation yet? Look to the older guys.
