As I posted in another thread, I have just acquired a used Laguna IQ CNC router (Aspire included) that came with a selection of router bits. The previous owner used it for sign making and engraving but I do not know if the bits he gave me are what I will need. What am I missing?
Here is what I got with the machine:
Freud #87-108 8-Piece Sign Making CNC Router Bit Set - $199.97
(1) Freud #20-108 V-Grooving Router Bit, 3/4'' Dia. x 1/2'' H x 90° x 1/2'' Shank, $33.47
(1) Freud #20-152 V-Grooving Router Bit, 1/2'' Dia. x 1/2'' H x 60° x 1/4'' Shank, $
(1) Freud #72-101 Ball-Nose Up-Cut Spiral Solid Carbide CNC Router Bit, 1/4'' Dia. x 1/2'' H x 1/4'' Shank, $33.47
(1) Freud #72-202 Ball-Nose Up-Cut Spiral Solid Carbide CNC Router Bit, 1/4'' Dia. x 1-1/8'' H x 1/4'' Shank, $38.97
(1) Freud #72-300 Tapered Ball-Tip Solid Carbide CNC Router Bit, 1/32'' Dia. x 1'' H x 6.2° x 1/4'' Shank, $46.97
(1) Freud #72-400 Tapered Ball-Tip Solid Carbide CNC Router Bit, 1/16'' Dia. x 1'' H x 5.4° Taper x 1/4'' Shank, $46.97
(1) Freud #75-102 Up-Spiral Router Bit, 1/4'' Dia. x 1'' H x 1/4'' Shank, $25.47
(1) Freud #76-100 Down-Spiral Router Bit, 1/8'' Dia. x 1/2'' H x 1/4'' Shank, $22.97
Freud #87-408 3-Piece Sign Making CNC Router Bit Set - $54.97
(1) Freud #70-103 Engraving V-Groove Solid Carbide CNC Router Bit, 3/16'' Dia. x 1/2'' H x 7.5° Taper x 1/4'' Shank, $22.97
(1) Freud #18-106 Round-Nose Bit, 1/4” Shank, 5/8” Radius, $47.99
(1) Freud #19-102 1/8" Radius Dish Carving Bit with 1/4" Shank, 7/16” Diameter, $30.99
MISCELLANEOUS BITS:
1/8” BIT COLLECTION
(2) Spiral Up-Cut, 0.124
(1) Solid Carbide V-Groove Engraving Bit, JLUO 5x5 (White Case)
(1) Solid Carbide V-Groove Engraving Bit, JLUO 5x7 (White Case)
(2) Solid Carbide V-Groove Engraving Bit, 0.40S (Yellow Case)
1/4” BIT COLLECTION
(1) Chinese Flat End Mill, Up-Cut, 0.236
1/2” BIT COLLECTION
(1) Chinese Ball End Mill, ½” shank
(1) Chinese Flush Trim Mill (Spoil board), 1/2” Shank, 1.127 Diameter
MISCELLANEOUS BITS:
1/8” BIT COLLECTION
1/4” BIT COLLECTION
1/2” BIT COLLECTION
