Bought this Record 52 1/2P vice quite a few years ago for $30 used and it sat around in my garage and in my basement ever since - collecting rust.
For the record (pun intended) the "P" signifies a "plain" screw, that is, no quick release. The jaws are 9" wide with a depth of 13". Oh, it weighs a ton.
Anyway, I've done electrolysis rust removal before on some smaller items, a couple of old Stanley planes and irons, but never on something this big.
I won't go into the details of the process setup as I'm sure you've all heard of it or tried it. The vice was frozen and nothing moved on it so I started off by spraying some 3 in 1 on the threads and let that soak for a while, then slowly turning the handle a bit at a time until it finally started to move. Eventually I got the vice apart into it's various parts.
I left the vice in a large rubbermaid tub filled with water and some washing soda, connected to an old battery charger and let it sit "cooking" for about 30 hours. Finally removed the vice from the solution, washed it down with some warm water and detergent, dried it off and sprayed some more 3 in 1 for temporary lube and to prevent further rusting. Now I've got to build another work bench around this. I've currently got a cheap 7" vice in my smallish workbench that I've been using for a while, but this Record is going to require something more substantial. Did I say it was heavy???
Here are some before and after pics:
