I am trying to understand the math behind any given router bit (for instance a 5/8", 14 degree or 3/4", 7 degree), the depth of cut that one should expect to set it at to produce a tight joint, and the thickness of the wood it can be used on.
I like to avoid traditional dimension lumber in my projects, but the above has been the source of many BTU's and I'm curious if anyone has this figured out. Manufacturers are great at specific dimensions and profiles, but thats only a beginning.
Thanks in advance for your responses.
