Removing price labels
13K views 44 replies 26 participants last post by  CharleyL
What is the best approach to removing those intrusive, gummy, price labels on wood?
I found a small sheet of Birch plywood with a great grain pattern, right in the middle of which was one of those big price labels that would not peel.
Sounds like a great opportunity for one of Stick's brews.
easy on the heat...
hair dryer - heat gun may cook the wood and it will show up in the finish...
turps for the residue....
I used a type of really soft rubber wheel that fits in your drill and is specifically designed to remove pin stripping off of vehicles . I think it was from Napa
an eraser...
Eucalyptus oil....
I use Benzine to get the sticky labels off anything - not sure if it will damage the natural oils in the wood though.
Lacquer thinner works for me.
#20 ·
you got that right...
#13 ·
Just about any petroleum base solvent will work. However, some are more invasive then others. I recommend and use plain Mineral Spirits. Mostly to remove scroll saw patterns from my wood; enough to thoroughly wet the paper and degrade the adhesive, wait a few minutes and the patterns peel right off. It doesn't harm the wood or effect any finish. A quick wipe removes any residue and evaporates quickly.
WD-40 works great to soften sticker adheasives, but I NEVER use it on wood. only metals, plastics or similar materials.
I try and stay away from things like Naphtha, Acetone, etc. Lacquer thinners are in this group...too aggressive. They are a last resort to remove stubborn residue. If I do use them, it is on and wiped right back off.
Hope this helps.
Bill
Trichloroethylene and Perchloroethylene are very toxic and easily absorbed into the skin... and easily inhaled damaging the lungs. Trich never leaves the bloodstream once it is there. It can cause all kinds of health problems. Naphtha (Benzene) is not quite as bad but still can be a health hazard. (I absorbed a lot of this from overfilled Zippo lighters in my youth).
I would caution that if you insist on using Trich or Perch that you use the proper gloves and a good chemical cartridge respirator, or a VERY well ventilated area.
I won't preach any further then this...
There are much safer alternatives available.
Bill
Heat gun, applied lightly, just enough to loosen the label. Then go down to any dummy that applies labels to the middle of the finished side of plywood and fry their A$$! They do the same to poster boards, which I use in my courses and used to be able to use both sides.
#22 ·
marketing knows this...
that guy is getting paid to put the sticker where it is...
Went looking for Xylene in December...paint stores looked at me like I was a Neanderthal. Found it at my local lumberyard, in the fibreglass section. If I hadn't asked a clerk, I wouldn't even have thought of looking for fibreglass section...
I'm in the process of installing new (cheep!!) hollow core slab doors on the second floor since the previous owners kids must have used them for either kick ball practice or 'fine art' displays with yards of scotch tape. All but one of the new ones, Jeld-Wen must have used the most aggressive sick-um labels ever produced by man. I ended up with a heat gun on low along with a sharpened (but not too sharp) 1" flexible putty knife just to peel those labels. That stick-um mostly came off but the remaining goo was removed with some 70% rubbing alcohol after trying mineral spirits. The mineral spirits just seemed to turn it into a gooey globs. As far as personal protection - nitrile gloves (Harbor Freight) and a fan, but those gloves will soften and tear so a pair per door at least will be needed. Automotive paint grade thinners (that I have) - strong stuff that would require, IMO, organic vapor respirators as it is quite toxic.
#40 ·
I purchased nine nice sheets of birch plywood a few weeks back. The sticker guy must not have been a woodworker as he put the stickers (not one, but two) on the good side. Why not the other side?.... Told the manager and all he said was "that is the way we identify the produce". He did't get it either.
