1 - 13 of 13 Posts
· Registered
Hi brand new to the forum and have a question. I bought an internal radius bit to cut a finger groove in the ends of cutting boards but quickly found out that I cant get the depth I need to put the groove in the center of the board end. However, after removing the plastic base plate from the router it gives me the additional ~1/4" depth im seeking. Are there any safety issues I'm missing by doing this or will the risk simply be potential marking of the workpiece due to metal on wood instead of smooth plastic?
· Registered
Welcome to the forum. I haven't used that type of bit, had to Google it, do you mean one like this?
Which router do you have? The ones I've used the metal of the base is nearly the size of the plastic so stability should be ok. I might not slide smoothly, so you'll need to control it without being tense etc. And you don't want the collet to touch the wood.
· Registered
Discussion Starter · #3 ·
Yes those are the ones I hadn't seen them before either but if I can get it to work it eliminates the need for a router table and/or jig which I like the idea of.
I have an old Craftsman 315 router and the plastic is the same size as the metal. I did a dry run just to see how it would glide and it seems to be ok but I may try some packing tape or something to help it along.
I didn't even think about the collet touching so i will take a closer look at that. Thanks for the input!
· Registered
Discussion Starter · #5 ·
Yeah i made sure of that. That's actually the reason i started exploring other options, looked into a collet extension since i know not to pull the shank out any further than it should be but apparently those are only supposed to be used on router tables.
I'll give this a shot and see how it goes. Just wanted to make sure I wasn't overlooking something.
· Super Moderator
John
.>`well I guess it worked Looks good
· Registered
So here it is I had a thin sheet of polystyrene lying around so I put a few dabs of super glue to hold it and it worked great!
Hi. Welcome to the forum, Bales9er.
I like the position of the finger groove at the cutting board's edges. It allows using any board face.
Nice cutting board. What is the darker colored wood? Where have I been, I,ve never seen a bit like that before.
Art
1 - 13 of 13 Posts
