1 - 7 of 7 Posts
Discussion Starter #1
I have ~20 year old B&D 7616 router that has given me great, relatively light use over the years. I think the bearings are going as it recently it's started making a horrible screech when I run it. Had a small job I was eager to finish so pressed ahead as it seemed to be working anyway.
Has it likely given up the ghost? Worth repairing? Who might do it?
Thanks for any comments.
If I replace it, the only one I can afford is the basic Dewalt 616 -- can't justify the $$ for the plunge base. Opinions?
Thanks in advance.
Welcome RS. Bearings can be replaced, by yourself if you have some mechanical knowledge, and are fairly cheap. The question is whether you fried the wiring by pushing ahead. When it starts running slower than it should it starts drawing more amps and heats up. Have a look at recon Bosch 1617s.
Reactions: Mike
what you said...
and...
also look to the 1617EVSPK-R
Reconditioned Routers and Trimmers
the Bosch tools are about as good as you are going to get...
their customer service gets 6 stars out of 5...
no worries on the reconditioned...
CPO is a very good company also..
Agree with Stick and Charles. You will be glad you took their advice.
Ross
Welcome to the forum.
...are you sure the brushes are good...?
RS, while repairing your old router is possible there is great advantage in replacing it with a new one. If you can only have one router it should be a plunge router since they can do much more than a fixed base router.
There is a great deal of information in the "Sticky" threads at the top of each section of the forums. Here is a link to the first section to get you started:
http://www.routerforums.com/general-routing/55897-how-tos-information.html#post506073
1 - 7 of 7 Posts
