1 - 8 of 8 Posts
Discussion Starter #1
OK Lil CNC buddies. I have a guy who wants about 50 address signs. All the same shape (very simple), pocket cut with all different numbers. With Aspire, I can lay a piece of Corafoam big enough to make 12 at a time (2 rows of 6), so how do I set it up to cut all 12 signs with one touch off -- but with different numbers. I can use the same 1/8" end mill to do the pocket and profile cut.
The only other way I can think of is to cut a bunch of blanks, make a jig, and just take a finished one out and plunk a new blank piece in, one right after another. That way I wouldn't have to touch off the axis every time. Just hit "go".
HJ
Technician in training
What I have found is it is much faster to break down the material to blanks on a table saw or band saw. Cutting the perimeters with the CNC, then removing tabs is much slower in cut time and post processing. I put wood strips on the table to register the Y axis and X to Y0,X0. Then fasten another strip about 1 inch above the material (Y axis) and use some wedges to keep each blank in place. I've made over a hundred signs this way.
Steve.
I find it almost easier to do like you said. Make a quick jig, and put one sign in after another. Usually after the first sign, i have some sanding and finishing work to do while the 2nd sign is being cut, so im usually by the router anyway to put the next one in.
Just my 2 cents =)
Discussion Starter #5
Bill, that's easier said than done - - especially at the 2/3 mark to the finish. Should know Mon or Tues whether I get the job or not. You may be hearing from me.
HJ
Discussion Starter #7
Thanx Jay,
Putting the stuff down and "designing" isn't too much of a problem. It's getting the right thickness on each component to make them blend in that is giving me fits. Hopefully I'll get a better grasp on it this coming week end when I meet the Vectric people in Vegas.
Also supposed to meet Scottart there. Hope to bend his ear and get some good tips on doing wildlife scenes and finishing.
HJ
Run your periphery on all pieces on one program. Run the numbers on another. But like stated it may still be easier to them separately.
1 - 8 of 8 Posts
