It was time to replace a chair that the dogs had 'modified', the day after I had a near miss in my shop.
The drum sander stand collapsed, causing the end bell to hit the block wall. The end bell was dented, and the fan was a little twisted.
A little body and fender work and the sander looks to be OK, but I definitely needed to make a more robust stand. The sander weighs a ton... and needs a beefy stand.
As I was looking to see what wood I could scavenge from the chair, I saw that the stand could be the chair. I cut the feet off of the bottom of the chair, so that it was a flush square, but I left the ledge on the back of the chair because of the number of staples is it. I had a few pieces of 2x decking material that would work for the bottom shelf, and a HF furniture dolly that is almost exactly the same size as the chair. A ton of pocket holes and a handful of coated decking screws and it was done.
It ain't pretty, but it is built like a tank. It held me and the sander without even noticing. As a bonus, the air compressor fits underneath, so I save floor space. I can mount a hook on the side to hold the air hose as well.
The stand is temporarily mounted to a HF furniture dolly, which works great. I will probably try to find a locking caster set, but for now it does just fine. I have to get some longer carriage bolts to anchor the sander down, but I think it's going to be a keeper.
Saved another piece from the burn pile, saved a few bucks on building a new stand.
There is about 7 inches above the heads of the compressor, and open on both sides, so lots of airflow around it. It fits in if you put it in on a slight angle. Most importantly, it solves the only problem with the compressor, the handle is too low to the ground.
Great idea ,Doug, I would give you like ,but my like button is not working along with other features. Glad your sander wasn't damaged. I don't know what I would do if I ever lost my drum sander. That compressor will give you some added ballast too.
That is a Ryobi drum sander, long out of production. I picked it up used, had to do some work to the feed mechanism. Even with the headaches, it is a definite time saver!
Ryobi customer service still does a good job, they were very helpful.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
