I've sanded my Unisaw with a ROS sander and 220 grit to clean it up.
Did the saw have any extension wings? If not, I'd be on the lookout for some.
Nice project. How are the innards? Rusty but cleanable? Will be fun to follow.
Some of the older Craftsman saws were pretty good saws. The really old ones were very good saws at the time. Some of the fences could be improved on with an aftermarket but the older ones were good enough to get by. One thing you'll benefit greatly from is an outfeed table. The distance behind the blade is pretty short on those, similar to an old Rockwell I have for a backup. In fact that just might be a Rockwell.
Good job on the restoration, it looks great.
What is a flex drive ,I have never heard of that? It looks like a belt drive to me.
@qulevrius Duh, Now that I look at the pictures again, I see the flex drive. I have never seen one before. I thought it was a belt drive and that the belt loose ,off the pulley. I wonder who thought up that kind of set up after all the years of tried and true belt drive. I have a direct drive 12" Craftsman and love it. I use it mostly with 10" blades, and the power is unstoppable,on 220v.
@PhilBa a piece of white tape works too. for the exact-ti-cut
@qulevrius I did a search on that saw, and it seems the weak link is the flex drive. They do not seem to be available for replacement. Some guys have changed them over to belt drive, but they say that it is a PITA.
It will probably serve you well if you baby it along and don't put too much money into it, save that for a future saw.
You could probably use an 8" blade too. You have to remember that the smaller blades have slower rim speeds ,so you have to adjust your feed rate down some, but you probably do that automatically by the feel of the saw. I know I do.
My 12" TS is an induction motor, looks like the 12" Radial Arm Saw Motor.
