21 - 27 of 27 Posts
It looks like the older Delta saw (36-320C) that I posted about earlier may have originally come with a splitter and kickback pawls according to the parts list that I attached below. I came across two other larger units (do not consider buying as they are way out of my budget) that also seem to lack riving knife / pawls. I assume that they are more popular with the smaller portable, big box store models.
Peter...splitters/riving knives were put on virtually all table saws since the mid-80's. Don't think you'll find a TS without one or the other manufactured after that. You may know a splitter is fixed on the insert or the table surface whereas a riving knife adjusts with the height of the blade because of where it is attached.
I have a very old Darra James 12" saw that has neither but I use a short fence to make sure there is plenty of room between workpiece and fence after the cut. I use fingerboards to hold the piece down and towards the short fence for safety and accuracy.
Good luck in your search...
The micro jig splitters are easy to install. I figured it out watching a video. And reading instructions.
I made a zero clearance out of some phenolic I had, used a trim router around the original.
I had to sand down the edges of the phenolic to fit. It works well.
The micro jig splitters is only pushed in.
Can be easily removed if needed.
Edit:
Forgot to mention I bought a ridgid ts2424, I think I paid 250. I'm more than happy with so far.
I totally understand when you say all the good stuff is gone quick online!
Premium Member
I had a Delta 1hp direct drive saw for several years. Bought it new for $300 on a clearance about the time Delta sold out to the same company the bought out Porter Cable. It was a little under powered. I got $250 for it. I think it went for near 600 new. It had a splitter that was attached on the rear of the saw, which was a kludge, so I installed the microjig on the inserts. Worked OK.
Definitely set up an outfeed table. There are dozens of simple designs. Rockler had a hardware kit for one that fit the Delta and later fit just as easily on my Laguna TS. The Delta often bogged down and blew the breaker, the Laguna is still 115 v, but it's 1.75 hp, American motor, and doesn't bog down on anything I've thrown at it. Won't be adding 220 in my shop, but many garages today have 220 available for electric dryers, so if you're using gas, that could be tapped BY AN ELECTRICIAN.
I stopped using narrow kerf blades long ago so the Laguna Splitter is full kerf and really easy to install or remove. I suppose you can get pawls for it, but I haven't needed it. I had one kickback way back when I first got the saw. Took two months for the pain to stop, so I now stand off to the side, out of direct line with the trapped piece.
I also have a Shark Guard for dust collection at the blade. It comes on a riving knife that's specific to the saw. It does cut down on stray sawdust, but it is just a little awkward to use, and the mount gets in the way unless I raise the blade an extra inch, which isn't the best way to cut 3/4 stock. Impossible to use for cutting narrow strips.
If the fence doesn't work right, check the aftermarket fences. My two cents.
Discussion Starter #24
Edit:
Thanks for chiming in Nick. I watched the video on how the MicroJig splitter gets installed. Looks really neat! Great little innovation.
I have had the Ridgid R4510 (granite top) for 10+ years and have been very happy with it. It looks very similar to the one in your pictures. It took some work to get it adjusted and I replaced the miter gauge which helped a lot. I need to replace the fence but I need one where I can attach my router insert. The saw has enough power for the projects I throw at it. The mobile base is great.
Discussion Starter #26
Thank you for chiming in sir. I made an offer on a used Rigid TS3660 a few hours ago. I'm not holding my breath as these saws tend to fly soon after they hit the Marketplace. The one thing that irks me somewhat is that the LSA is not transferable. Understandably so. And, there is nothing like having a warranty when something decides to go wonky on you.
Have a wonderful day and keep enjoying that saw of yours.
21 - 27 of 27 Posts
