I get a better cleaner cut with a 40 tooth gp blade when I'm ripping for glue line.
you know that rip blades are thickness rated....I'm going to be ripping about 150bf of 2" thick Figured Maple. Will a 24 tooth rip blade give me the best cut? I have a gp blade right now, but the better the cut I can get the better off I am.
Sent from my SM-G955U using Tapatalk
That depends on his bandsaw and how long the pieces are, Herb. Same restrictions apply as in the table saw - sufficient HP and blade capacity to handle that sort of stock for anything more than a short cut. Most hobby shop bandsaws won't handle 150 bd. ft. in one setting; likely to burn it up. 150 bd. ft. would have to be spread over a long time. It does reward you with a thinner kerf if you cut straight enough but it's a wash if you have to cut very much on the jointer (hard to manage a straight line if these boards are 8' long and there's any blade drift).Anything over 1 1/2" thick I rip on the band saw and then use the jointer to finish the edge.
two passes with a better blade...Well hell...
Maybe I'll have them rip it for me. My little 1.5hp might not be able to handle that
Because it doesn't increase the HP. Unless that's some one in a thousand motor I never heard of, simply changing 120 to 240 does exactly zero to increase power. At best you might run the motor cooler."If your saw is a Delta contractor saw and you switch the motor to 240 volts and connect it to a 240 volt circuit you will get a full 2 hp from that original motor. This will make a big difference when trying to rip thick material
-Charley
First thing I did with mine.
I know I get more torque, but I didn't realize that actually equated with an increase in HP. To be honest, never really thought about it in those terms.
That probably sounds wrong, but the armature gets a kick every 120th of a second instead of every 60th...just assumed it meant the blade had less opportunity to slow down.
Physics was never my long suite.
