Please excuse the dumb question but I was given a set of Porter Cable guide bushings and I’ve never used them. I have a Porter Cable router mounted in my router table with a Jessem router lift and base plate and a Incra Clean sweep setup. I like to do handcut Dovetails but I’m 74 and have a hand deformity that makes it tough to get the base of the Dovetails cleaned out without buggering the straight baseline. Is it possible to mount the bushings to my table router setup and use a straight bit to clean them out. I saw a video from Fine Woodworking that showed a fella using a pattern bit with a top bushing doing it very easily with his hand held router. Excuse the rookie question.
