1 - 16 of 16 Posts
· Registered
I have a Roughneck 4# hammer that's got a fiberglass handle marker Olympia 65-164 - lifetime warranty. The handle came off the head. I can't find anything on Olympia tools that even comes close. It's a few years + old. Was going to pitch it, but figured might be worth trying to get it replaced. Any ideas?
· Registered
John I will be 75 years old in June and a life time warranty doesn't mean as much as it use to. Maybe Olympia tools are old also or even passed on.
· Registered
epoxy it back together...
clean, dimple or rib both surfaces horizontally for better adhesion....
Reactions: Danman1957
· Registered
Theo
The company is still in business. Olympia Tools
To me it is simple, get up with the company.
· Registered
· Registered
for the 50¢ to and 10~15 minuets to fix it... wouldn't this be the better easier faster way...
Reactions: Shop guy
· Registered
Discussion Starter · #8 ·
I'd fix it if the repair would hold. I did some serious pounding over the years with this baby.
· Registered
use the high impact never gets hard/brittle epoxy/hot melt the golf shops use...
Epoweld is what I think it is called... read the specs for the right one...
Masterbond makes a polymer that is some serious stuff but the price will hurt your brain...
you are looking for Vibration, Impact and Shock Resistant Adhesives/epoxies/polymers...
· Retired Moderator
Buying the epoxy could more than the cost of a new hammer. Some of those tools can be converted to wooden handle but not all. Some don't have a tapered socket which is necessary for a wooden handle, and the new wooden handle could cost as much as a new tool. I sent my wife looking for a handle for my pickeroon and none fit and the closest ones (single bit ax handles) were $25.
· Registered
Discussion Starter · #15 ·
may try the epoxy thing. The handle is good, just came out. Would cost more to send it back than I paid for it - - which was probably $12-15 at the time.
· Registered
I replace a 12# sledge handle several years ago with a fiberglass handle. If I recall correctly I bought the handle at the local BORG, and it included the epoxy. I believe they had the epoxy kits there, also.
The repair has lasted for over 20 years with no problem.
1 - 16 of 16 Posts
