counterclockwise - same as you would do for an outside edge.
one direction will give ya fuzzy edge to the outside...According to Pat Warner, it doesn't matter.
Doesn't matter on plywood or MDF. Make your pattern from either, rough cut your blank, attach pattern using brads or double-stick tape and cut using a pattern bit. Change direction so you're not cutting against the grain - if you've cut close to finished size when roughing out the blank, climb cutting shouldn't be a problem - and you'll get a nice clean cut.one direction will give ya fuzzy edge to the outside...
the other to the inside...
pick yur poison...
Last circle cut was for a ring for the duct collection cyclone. It has a circle cut inside the ring, like a flat donut. I used a quality 4 TPI blade which produced a really nice edge on the outside, and a jigsaw on the inside circle, which wasn't quite as smooth. But that's what they make sandpaper for, right?Tom, I have a bandsaw circle cutting jig, I just wanted to experiment with the router. OOOPS. Wont make that mistake again.
I'm making a lazy susan, with tile insert. I'm now chewing the internal wood away to allow a 10 mm tile to sit flush inside the 20 mm edge.
I think I'm doing everything on this build in the hardest way possible. But hey, its a hobby, right?
Just visualise the bit in a groove, if you go clockwise the bit cuts into the wood and it still cuts into the wood going anti-clockwise.Not to argue with my betters... but it did go slightly smoother anti clockwise, less jerkiness. As far as the cut edges, I couldnt see a difference.
