Rousseau table and box joint jig
2151 Views 3 Replies 3 Participants Last post by  pitonyak
I have limited space and I will need to move my router table around, use it, pack it, etc. I want to build some boxes to store firearm ammunition (so I can lock it).
I was looking at the oak-park box jigs, very cool, refered there from this forum.
Any idea if I can use these jigs on a router table such as this?
it looks to me like the fence/vacuum system might be in the way so that I could not easily use the box jig.
Any comments are appreciated.
1 - 4 of 4 Posts
Is this the router table you have Andrew?
http://www.amazon.com/Rousseau-3100...=pd_ts_hi_27/002-2236787-8368837?ie=UTF8&s=hi
If so, I think it would work ok. You will have to drill it. See my Wooden Stuff Blog or the how to section of the forum.
Here is a knock-down router table:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=28007
The Oak Park spacer fences for box joints could be mounted on this table and used for making box joints.
I do not yet own a router, or a router table. I have spent a lot of time thinking about whta I should really purchase.
my initial use will be creating these boxes. I do not even have a design for the boxes, but that will come...
My first thought was to purchase a jig such as the PC 4212, but the box thing was recommended, so I checked it out. My opinion is that it is a much better match for what I want to do. For this, I should use a router table.
Space is a serious issue for me so I figured that something that can be taken down is a very good idea so I was thinking about the Rousseau 3100 and perhaps even adding a Rousseau 3002 Router Lift LS.
I must admit that the "knock-down router table" is very interesting as well. Even if I purcahse the Rousseau, I can imagine making the knock down table, perhaps with some modifications. The advantage with the Rousseau is that I have no local mentor to give me a kick-start. I could then use the Rousseau to make other things. Might be able to rig some things to make the knock-down, however.
Challagan, your entry in the blog is very useful. In fact, this is exactly what I needed to see. It had not occurred to me that I could simply drill my own holes.
1 - 4 of 4 Posts
