This is my first post on the forum
This is some pics of the Router Adjustable Dado Jig I have just made.
To do dados I have been mounting the Triton Router Table on the Trion 2000 saw bench and measuring from the fence to get the right width of the dado but this has been a bit of a pain.
With this jig which is 900mm long is just a matter of putting the board into the slot and bring the movable side up to the board and tighten the knob and this gives you the exact width of the dado, you then line up the fixed side of the jig to a line drawn on the work piece and clamp the jig to it.
It is then just a matter of setting your router to the right depth and the router runs up against the guides on each side of the jig.
I set it up to use a 12mm router bit using the Triton Router.
The design came from Woodsmith Custom Woodworking, Shop Built Jigs and Fixtures.
This first pic is of the back of the jig and the second is of the front.
The plan said to make it from ¼" Masonite (Hardboard) with the base made of two layers contact glued together with a single layer for the guide. I decided it was easir to make it from 12mm and 6mm MDF with the ends made from a bit of Meranti.
