Router bits with no bearing
16K views 17 replies 11 participants last post by  DaninVan
Can a profile router bit with no bearing be used with a hand held router? I have seen some profiling bits such as bullnose bits and was wondering how you would use them with a hand held router if they have no bearing.
Hey, N/A; welcome!
If you have a moment perhaps fill out the personal profile with at least your first name(?). It makes it a bit more friendly.
Re the edge treatment and bits; I hardly ever use a bit with a bearing; I much prefer using a micro adjustable edge guide for hand held routering.
What brand of router are you using?
RA1054 Deluxe Router Guide | Bosch Power Tools
Other brands of course are similar.
The Bosch model also can be used for routing circles: (I personally haven't tried it but other members pointed this out to me.)
https://www.youtube.com/watch?v=I-2uBRG6LI0
Done. I am using a Bosch 1617 EVS. The edge guide looks like it would be the way to go for using edge forming bits with no bearing. Should I go for the Bosch edge guide or is there something else that would work better?
Hello Rob welcome to the forum.
Yes but to use these bits you must have some sort of guide system in place , like Dan says edge guide,a board clamped to guide the router
Rob; :)
I love my Bosch edge guide. If there was a third party one available I wouldn't even bother considering it. I don't know what Bosch could do to make there's better!
Price shop though; quite a spread in the online posted prices.
I have an old Craftsman router with a similar guide but it's no match in quality.
Your routers are sold without guide fences! Amazing!
Yeah...what a country...if there was another one like it I'd go there for the weekend...
My Bosch 1619EVS came with one (the one I referred to). Bunch of other stuff as well.
What really makes me crazy is that no one includes a rip guide with builders' saws over here (anymore). That's like not including the power cord...
It's basically a stamped bar welded to another bar, and a screw. Worth what, $1.50 to make?
Gee, Dan, what a bunch of cheap skates. Over here if they did that the dealer would get a real ear bashing. Of course Festools are the exception :yes4:
Regards
Phil
#13 ·
G'day Rob, welcome to the forum.
An alternative might be to clamp a straight board on top of the work and use a guide bush. The fence on my De Walt 625 does have a micro adjuster but its quite sloppy and the fence shifts quite significantly when you clamp if after adjusting. Clamping a board or a template over the work might actually be easier and gives a good wide surface for the router base to ride on. If you made a small spacer to use with the chosen guide bush it would easy to set it up the same each time (attach the guide to the board with a piece of string and mark the guide bush size on the guide to avoid using the wrong bush by mistake. I do this on all my templates.
