Has any one used spiral router bits and if so do you like them
They should work better for that. With a straight bit all the force is applied to the wood at the same time over the whole of the cut. The spiral means only a very small section of the bit makes contact at any time so it should be less prone to chipping out.i will use them for cutting dove tails
