I am putting the finishing touches on this machine I made,. I always wanted a full sized air plane propeller with a clock in the hub to hang on the wall,, and could never figure out how to form the blades of the prop so they looked real,,, and I stumbled on an article in a magazine about some guy that makes props for air boats,,, and over his shoulder was the machine he used to make them,,, so I searched on the net and found some machines and used a combination of them to come up with my version of a machnine,, While I was researching, I seen exhamples of projects that were being made in these machines, that I never dreamed of before,,, so this machine should be a ball to play with once its up and running.
The router is a porter cable purchased off Ebay. And I still have to fabricate the attachment that you will mount the pattern and your workpiece on, that will allow you to rotate them, both to the same degree, so you can duplicate just about anything in wood, in 3-D.
