I have wondered why someone hasn't created a balancing wheel for many tools, such as bench grinders, and routers, and essentially ANYTHING that spins quickly and has a tendency to become slightly out of balance for any given reason.
These CENTRAMATIC balancing wheels are used on wheels of vehicles and motorcycles. They are a flat plate with a circular tube. Inside of the tube are tiny ceramic balls that move freely around the interior of the circular ring. They work well to balance loads, since an unbalanced load has speed differentials between the segments that rotate faster (around a larger orbital path) and those segments that follow a smaller orbital path. The beads move around inside and gravitate to the slower areas, thus balancing the wheel.
I use DYNABEADS on my motorcycle tires and trailer tires. They are awesome for maintaining the balance of wheels through their lifetime. As the tire wears, or a rock takes out a chunk of rubber for example, the beads move around inside of the tire to compensate for that change in the centrifugal force of that small segment of the wheel, replacing the weight of the rubber chunk that was removed.
I suppose a balancing wheel COULD be made for a router spindle, and I am guessing that it would improve the performance of the router, if someone would only INVENT the dang thing!
Here is the company that makes the balancing wheels.
Joe
Joe
