1 - 9 of 9 Posts
Discussion Starter #1
New to the forum. Hoping someone can shed some light on an issue I'm running into with my router lift. I can set the height I need but once the router is on for a brief time the bit will drop or raise in height. Original lift was a Jet Xacta lift made by Jessum. Thought it was an issue with the lift itself so I purchased a new lift from Woodworkers Supply this weekend. Finished setup this afternoon and the problem is reoccurring with the new lift. Router motor is from a Porter Cable 690 with 1/2" collet. Issue happens with multiple bits. Almost seems as if the router spindle is out of tolerance. Any thoughts?
WTB it's the routers collet...
days end or just needs maint...
Welcome to the forum, Ken.
Welcome Ken. I would have to agree with Stick. The most likely culprit is the collet.
Premium Member
Try putting a small rubber grommet into the collet. About 1/8th thick. Then you can bottom out the bit on the grommet which may help. If that fails, replace the collet. If that fails, get a Bosch.
Weccome to the forum ken
If it happens with multiple bits then it would appear to be the collet. I had a problem with a 1/2" roundover bit slipping in my Bosch 1617 but it didn't slip with any other bit. Replaced that bit and problem solved.
since then I have replaced my collet with a Musclechuck and it is even more convenient for bit changes and none have slipped.
Reactions: RainMan 2.0
1 - 9 of 9 Posts
