Barely Used Router Parts CNC Benchtop Standard 2424. Comes with everything you see plus a table for it to sit on. Asking $5500. I am located in Northern Virginia so you will need to pick up.
1 x Benchtop Standard 2424 2' x 2' CNC Machine Kit
1 x Plug and Play NEMA 23 CNC Control System
- Cable configuration: (3) 12' and (1) 20' cable
- Motor Shaft Diameter: 3/8" (Low Inductance 420 oz-in)
- Additional Motor Drive: None [4-Drive, Standard]
1 x Pepperl + Fuchs Proximity Sensor Kit
- Sensor Configuration: Homing/Limit 6 Sensor Kit (4'x4' machines, or smaller)
1 x 2.2 kW Plug and Play Spindle / VFD System
- Compatibility Option: CRP800 (Standard)
1 x Tramming GMT Spindle Mount
1 x Auto Z and Corner Finding Touch Plate
1 x ER20 Collet and Nut Set, 1/8", 1/4", 3/8"
1 x CNC Router Bit Set
1 x CNC Aluminum Cutting End Mill Set
1 x Benchtop Spoilboard Fastener Kit, 2424 (PRO and Standard)
