Good point Dan, make sure the router will exactly center in the hole in the plate.And you WILL need a centering tool!
https://www.blackrocktools.com/bosc...!!g!!&ef_id=WuEHNgAAALoG2mjc:20180426144048:s
I make my own plates, and that is how I started, and still do. Didn't even think about any other way. I don't find screws to be a problem, I keep track and am careful not to lose any. And, when I do lose one or two or three, I make sure I have spares on hand to replace them. One issue, forgot where I put the spare screws.All you need to do is take the black baseplate on the bottom of the router (which must be removed if installing into a table) and use it as the pattern. All the mounting holes are exactly where they would need to be for an exact template/pattern. Center the base plate in the hole in the plate first. I also suggest you get a plate with a twist lock insert rather than one that uses 3 screws, which are easily lost.
Why are you looking for the plate for MO001? MO001 comes with the plate. This plate fits into the Triton router table if you want to go to next level of capability of the MO001.I'm looking for some advice on a UK based link (ideally Amazon or ebay) for a router plate that will fit the triton mof001. I can't find any specific compatibility information for plates I've found. Thanks guys.
