On a table with a switch, the router needs the trigger locked on. I wonder if it could've turned off. Some routers don't have a trigger lock and the switch needs to be 'tied' in the on position. Either way manually pull the trigger to test.
Also you could try plugging the router in directly rather than through the table's switch.
Keep your fingers away from the bit.
