1 - 12 of 12 Posts
· Registered
I plan on building a Router sled for flattening large slabs for making tables (5-1/2’ ft x 10-1/2’ ft sled) and would love router recommendations that would be very well suited for this task. From what i have read a high horse power plunge style that has adjustable speed and micro adjustments would make good candidates but really like getting my information from people who really handle routers often can provide me with sound advise on the in’s and outs of different manufacturers ,functions and durability. Any insight would be greatly appreciated.🙏🏻
· Registered
What you have read is excellent advice. I use a Freud FT2200 which is out of production...I think. An excellent alternative would be the Makita RP 2301FC 3-1/4 HP plunge router with variable speed.
I like the straight sided base. Of course, a straight base could be made for a round stock base as on the PC 7518. But, IMO that beast is too heavy for the job. I have one under a table where it's better suited.
· Registered
Welcome to the forum. A plunge base should be used for convenience of depth adjustments as you go from all I've gathered on the subject and speed control is a must but most have that already. Here is a speed chart that gives you the suggested speeds for different sized bits. Also keep in mind that multiple shallow passes are safer then trying to deep on the cuts. I limit mine to no more then 3/16-1/4". You large sized slabs make me wonder how you can comfortably do 66" wide without moving from one side of the slab to the other considering reach unless you have a mechanical way to move the sled from front to back. Would be interested in what you come up with.
· Registered
Welcome. There are many routers that will do the job well. Anything 2.5 hp and up will do, just don't try to cut too much at once. I would never go more than 1/8th per pass with something like a Bosch 1617, but it meets all your requirements. Almost all of the name brand 3+ HP routers are top heavy. So I suggest you stick with the 1617 and make a few more passes.
I love my Triton under the table, but it's too tippy and top heavy for me to manage freehand, even with a guide. If your sled uses metal rods a really heavy router may distort the rods, tilting it will dig into the slab. A lighter router is less likely to do this.
· Premium Member
Retired since June 2000
This is the simple method that I use. I prefer a powerful router that has an easy life even when being used with very hard woods.
· Registered
Variable speed is a must, as you'll want to use a bit similar to an Amana RC-2555.
You only want to spin it at 12,000-14,000 rpm.
You don't need micro adjustment imo, as you'll be removing a fair amount of material with each pass.
You'll need a pretty substantial fixture to span 6 ft without sagging a lot, if you want truly "flat" slabs.
· Registered
The FT2200 is my choice, as well.
1 - 12 of 12 Posts
