1 - 7 of 7 Posts
Discussion Starter #1
How can I safely edge rout a piece of cherry approx 1" wide by 12" long? There's not much room between the fingers and the spinning bit.
Take a piece of scrap wood and cut it into an L shape and use it to push your small material through.
I too try to router while part of larger board but being new to woodworking the way Mike showes is good to know.
Steve
Hi James:
All of the other suggestions are bang on but I'm going to suggest something a bit different. I would use a bearing on a bit and a safety guide pin. To learn this technique go to
The Woodworking Channel
Select "videos" and slide across to "the routerworkshop." You're looking for the "Fern Stand" episode. Go across to about 18:55 and they'll show how to use the safety pin. In this episode they're treating an edge on a long slender piece similar to what you're doing. Watch where and how they place their hands. Your piece might indeed need a holder and the holder Mike is suggesting works for me.
Alternatively, you can use a table mount router, a fence and push sticks.
HI James
Sounds like a good job for the ski jig, with the ski jig your fingers are never in the path of the bit..
Discussion Starter #7
I like all of these ideas and will go with Mike's suggestion. Much thanks for all who offered their help.
1 - 7 of 7 Posts
