1 - 8 of 8 Posts
My 1 ¼hp router finally gave out after many many years. After doing some reading I decided to upgrade to a variable speed 2 ¼ hp (Porter Cable 892). I found a reference table which basically showed recommended speed for 1” to 2” and over. Later I read an article on rail and stile work, and it was recommended that you make 2 passes at 13000 rpm for oak for both rail and stile bits. My question. Is there some sort of reference for style of bit (i.e. cove bits) and router speed and type of wood? Or is there a general rule of thumb for hardwoods and softwoods and bits. Never owned a variable speed router before, so all this is rather new.
If this topic has already been covered just point me to the thread. Thanks.
RJ
Along the lines of what Doug said if you are getting burning it's because your feed speed is too slow or your router speed is too high. The bit is rubbing in the cut instead of removing wood. When the bit is removing wood it runs cooler. This varies from one wood to another. Maple for example is one of the bad ones for burning.
Reactions: chessnut2
this is all I have...
Here is a little math router manufacturers use when determining the all-important speed of the outer edges of bits:
Circumference = pi X diameter
"Tangential" speed (in inches per minute) = circum X rpm
So:
1" circ. = 3.1415 * 1 = 3.1415 ---> 3.1415in * 18000rpm = 56547in/min or 4712.25 ft/min or 53.55 mph
2" circ. = 3.1415 * 2 = 6.2830 ---> 6.2830in * 18000rpm = 113094in/min or 9424.50 ft/min or 107.10 mph
3" circ. = 3.1415 * 3 = 9.4245 ---> 9.4245in * 18000rpm = 169641in/min or 14136.75 ft/min or 160.64 mph
***As you can see from the above equations, a bit 1" in diameter, moving at 18,000 rpm is traveling at 53.55 mph at its maximum diameter. Likewise, a bit of 3" in diameter, also spinning at 18,000 rpm is traveling at 160.64 mph at its maximum diameter.
***So, lets take the example of someone using a 1" diameter straight bit at 18,000 rpm and changed to a 3" diameter roundover bit but did not decrease the router RPM. This person has, in effect, tripled the speed at which the tool is spinning just by keeping their set-up constant.
1 - 8 of 8 Posts
