1 - 10 of 10 Posts
Hi,
My Porter-Cable 690 router stops and starts when its orientation changes. For example, if I hold it right-side up it may run for a while and then stop, and if I then flip it upside down it will start running again. I changed the brushes because I thought that may be the problem, but the problem is still happening even with brand new brushes. Any ideas on what may be causing this problem?
Thanks.
Super Moderator
John
Hey Marc, welcome to Router Forums,I'm positive that one of the members will belong to help you shortly.
Discussion Starter · #3 ·
Thanks. Actually, I was just examining the router, trying to see what is wrong. I was testing it and suddenly the power cord caught fire where it meets the strain relief! So I suspect that the power cord was bad, which makes sense given the symptoms I was seeing. I'll replace the cord and see if that fixes it - I suspect it will.
Thanks,
Marc
Premium Member
Hi Marc. Welcome to our little corner of the 'net.
That is what I was going to suggest... sounded like a broken wire or poor connection somewhere to me.
Discussion Starter · #6 ·
new power cord fixed the problem
Just to wrap this up, the new power cord solved the problem and the router runs fine. Thanks for your help.
Marc
Doesn't it make you feel good when it's something cheap and easy.
Ross
Welcome to the forum Marc.
1 - 10 of 10 Posts
