1 - 7 of 7 Posts
Discussion Starter #1
Hi,
I'm in the UK, we have a national DIY chain, B&Q. Will their small router be suitable for doing some hinge and lock work. The router is the UB1020WR Black 1020W. This is the link to the spec if I'm allowed to post links yet :)
Oh no I'm not, this is the B&Q site, w w w dot diy dot com search for the UB1020WR and it will bring up the router details.
Cheers,
Peter.
Hi
That's a big router for hinge and lock work I would suggest you take a hard look at the T4 router..
Router UB1020WR Black 1020W - DIY - AOL Shopping
Trend T4EK 850 Watt 1.1-HP Variable Speed Plunge Base Router
Hi,
Cheers,
Peter.
Hi Peter.
The B&Q one is identical to my Einhell one, apart from the colour. Those are good little routers. They are a copy of an old Elu one. I've had mine for several years and been very pleased with it. At that price, you can't go wrong. If you ever need other guide bush sizes, Trend's ones will fit. If you need spare collets, Einhell's UK office in Birkenhead stock them. Bob probably thinks it is bigger than it is.
Cheers
Peter
Hi Peter
Is about the same size as the one below ?
Amazon.com: Makita 3621 1-1/4 HP Plunge Router: Home Improvement
Hi Peter.
Cheers
Peter
Hi Bob
I'm not sure. It could be, judging by the size of the handles.
Actually, when I had a look, there was a link lower down to JVL, who I've bought stuff off before
Hart router bits - JVL europe for diamond bits. They hadn't had them previously. Have you ever seen diamond bits before? I haven't.
The other router is about 2/3rds the size of a 625 and a useful size for smaller hand held work. I've 1/4", 6mm and 8mm collets for it. The 6mm and 8mm ones were standard ones but in the UK they sell the same one with a 1/4" collet, so I got a couple from Einhell in the UK. I use it a lot with an 8mm shank pattern bit for trimming.
Cheers
Peter
Discussion Starter #6
Discussion Starter #7
Hi Peter.
Cheers
Peter
Ok Pete,
I will get from B&Q next week when I'm out that way. As you say, good little router at a very good price.
Peter.
1 - 7 of 7 Posts
