I'm kind of working backwards on making a router table with all the controls mounted above the table.
For me trying to figure out all the electronics is probably the most time consuming part of this project, So I figured it would work out best for me to start with the controls that I wanted for the router table.
Awhile back I started a post on trying to figure out how to extend the wires on this DC motor controller.
The controller is eventually going to be used to power a 24VDC 120RPM gearmotor that will be used for a DIY router lift.
Along with the motorized lift I plan to add a digital readout like this one
so that I would know the depth of cut being made.
My plans at the time were to extend the wires & mount just the controls in a small control box that would be mounted up above the table on a repositionable arm, That way I could mount the actual control box somewhere below the table.
After thinking about a little more I started to look around for a larger box that I could just mount the whole controller in.
Well that led me into yet another one of those "Rabbit Holes"
With a larger box I had more room for other items & l could also mount the digital read out to the box.🤔
Being I will have the digital read out & the lift controls in one location, It also made since to have some way to know when the router bit is flush/even with the top of the table so I can zero out the DRO. After a ton of Google searches I came up with the idea to use a Arduino Nano with a modified Reed Switch Module & a relay to make a zero touch plate that will stop the router lift the moment the bit touches the plate.
This is what I came up with.
And here's a cut & paste version of what it will look like with the DRO mounted.
