1 - 7 of 7 Posts
Hi Folks! I want to find a single speed router that has brushes rather than being a induction motor. I am shopping on ebay for used since I want to use it to make a Bowling ball spinner. I will plug it in through a Router Speed Control and they require a motor with brushes and not a variable speed. Any ideas on a powerful model or brand to look for? I guess I should ask if all routers have brushes? Thanks for your time.
Super Moderator
John
Greeting and welcome to the forums Darrell.
Welcome to the forum, Darrell.
I leave electrical questions to the experts.....
pickup a Porter Cable 690 setup.
Ross
Welcome to the forum Darrell.
The PC 690 series that BJ suggested will be the easiest to find. As long as the router does not have a built in speed control it should do what you want. The most popular router motor for special applications is the Bosch 1617, not to be confused with the 1617EVS. This motor was used by the optical industry in lens shaping machines because of its heavy duty bearings and industrial quality construction. The 2-1/4 hp this model develops should be more than enough for your application; if it is not then consider the Milwaukee 5625 that is rated at 3.5 hp.
As long as your going to destroy it anyway, go to Harbor Freight and get a no-plunge router or other brush device. I got a single speed, no-plunge for 29.00 on sale and it actually worked, matter of fact I'm having a hard time killing it so I can get a Dewalt or PC motor only.
good luck - Baker
1 - 7 of 7 Posts
