I am very new to using a router. I need some advice on what is the best way to router circles? I am building a fire truck toy box and I need to router and or make some 10" circles. I would like to learn the router method the correct way. "Thanks"
Hi:
Welcome to the forums.
What I have done is to take an edge guide (BusyBee Tools, B2526) and customized it to work as both an edge guide and a circle cutter. (The web page for the B2526 is
Busy Bee's Summer 2009 Flyer Page 11 -- see lower right corner.)
The customization is simply drilling a couple of holes in the wood to take a 1/8 inch metal pin and providing support of the subbase on the opposited of the router.. (I replaced the wood piece on mine with a longer length of poplar and added a third hole at 19" from the pivot.)
After customizing the edge guide, I have found it great for edge guiding AND circle cutting. As a circle cutting guide, mine does circles from 1-1/2" radius to 20-1/2" radius.
To use, I drill a 0.120 inch hole in the workpiece. Tap in the 1/8" pin. Place the appropriate hole on the circle cutter. Adjust the wood strip position and route. Has worked well for me.
Future plans for my jig: add an MDF sub-sub-base to the acrylic sub-base, to turn the edge-guide/circle-cutter into an edge-guide/circle-cutter/edge-flush-trimmer. This allow me to flush-trim the oak edging that I'll put on my MDF core for a router table top.
Cassandra
