Routering a smaller piece
3.3K views 14 replies 8 participants last post by  bobj3
I've decided to mount some scrollsaw projects on elliptical bases with finished edges rather than hang them. The bases are all going to be 1 inch thick, and range between 10 by 4, and 14 by 5 1/2 inches long with a 1/2 inch wide x 1/2 inch deep dado down the topside within which to insert the finished project. Do I freehand the piece around the mounted router, or clamp the base and freehand the router around the edge? My experience with routers is limited to rough carpentry only - no finesse was required. I'd appreciate any suggestions. Thank you, Barry
Discussion starter · #13 ·
Pretty clear routering small, outside corners is an acquired talent and is going to take some practice. Also, after several phone inquiries I can see I'm going to have to fabricate my own safety pin from nylon dowel, and a bolt as per the video. My table doesn't have any threaded openings for safety pins, and rather than starting to drill holes I'll try to master small, outside corners with practice. Thank you to all, Barry.
