Hi
It can be done with good plywood (more than 4 layers without any voids in the plywood) and using a sharp (new) router bit.
a good way to test the router bit,put some paper on a wood block and cut the paper with the router bit with one pull of the router bit,if it cuts the paper you are good to use it, if not it will rip the plywood..
but it will be dull real quick cutting the plywood...so get more than one, and use router bit lube..
if it's worth doing it's worth doing it right they say..
