Routing a 45 degree slot.
1.8K views 7 replies 7 participants last post by  jw2170
First post and greetings from the Scottish Borders.
I have seen a you tube vid where it was mentioned in passing that they had screwed battens to the wall with a 45 degree edge. Then they made boxes to keep stuff in and routed a corresponding slot in the back of the box to "hook" it onto the batten. Suggestions for the bit please?
PH
You can get a router bit that will cut a 45 degree chamfer. I'd suggest using a router table to get the best cut and to have the best control when using such a large bit. Amazon UK has several available.
I would agree that a table saw might be easier if you have one in your tool arsenal.
G'day PH, welcome to the forum.
