I know there will be a lot of "ifs" in answering this question but I feel it's worth asking since it might save me days with my projects.
I glue up small panels usually consisting of two to four boards. Overall size of the panels range from 6" X 12" up to 24" X 24". All my wood is 4/4 and is usually hardwood although I use a lot of pine for my prototypes and jigs. My usual glue is Titebond II. I work in my basement where the average temperature is around 62 F and low humidity. My joints consist of edge to edge glue only joints. No biscuits, dowels or screws.
My question is this. How long do I have to wait for the glue to dry before i can work the panel. I'd like to cut it to final size and finish all of the edges on the router table as soon as possible without screwing up the panel. I currently glue up the panel, come back in 30 to 45 minutes and scrape off the squeeze out then come back again in about an hour and remove the clamps. Here's the part i question. Since the glue bottle says to wait 24 hours before stressing the joints, i wait until the next day before doing any final milling to the panel. Is the 24 hour wait time necessary? I know that if i'm too quick, and the glue isn't totally dry i'll gum up the router bit and i'm also afraid that if i'm too quick the panel may change its dimensions as the moisture from the glue leaves the panel.
If any of you work in similar conditions please let me know what your experiences have been and any other advice you can give me? With a limited number of clamps along with a limited work area it can take me days to get all the panels completed. I'd really like to reduce that time but not at the risk of ruining the project.
