Routing an Arrow in treated 4x4 posts
1115 Views 6 Replies 6 Participants Last post by  mgmine
I work on a golf course and am trying to make directional signs using 4x4 posts and routing an arrow in them to direct the cart traffic to one area. I cant find an arrow design anywhere. I've tried turning the K, A, and V vertical but it still doesn't work the best.
What's the easiest way to route an arrow?
Virgil
1 - 7 of 7 Posts
Welcome to the forum. I’m sure someone will be along and lend you a hand.
Hello and welcome to the router forum, Virgil
Welcome to the forum. Just google clipart arrow, there should be lots of them
Find the design you want or draw it. Then trace it onto a piece of wood of some sort (MDF, masonite, plywood), then cut it out with a coping or jig saw then use a bit like one of these to route it out. The bit will follow the template exactly so be sure to sand it nice and smooth.
4Pcs Pattern Flush Trim Router Bit Set 1/4 inch Shank Template Router Bits 1/2 inch Cutting Dia Woodworking Router Tool by CHoiKWong (1/2 inch Cutting Diameter, yellow) - - Amazon.com
Maybe I read it wrong or not enough coffee yet but the router bit will have a bearing for the sides to ride the pattern so you need to take that into account for the width of the arrow shape. Not having done this I'm wondering about the length of the bit and distance from the bearing to the end of the bearing.........brain freeze, use a collar not a bearing and adjust the depth...........it's like coming out of a coma sometimes. Or am I missing this all together?
You don't need a collar the bit you would use is determined by the thickness of the wood that you are using for the template. And yes the pattern needs to be a little larger or smaller to accommodate the size of the bearing. You can either route into the post or make a template to cut the arrow shape out of a separate piece of wood. There is probably stuff on Youtube about using a template with a router.
1 - 7 of 7 Posts
