routing flat panel cabinet doors
11K views 12 replies 9 participants last post by  bobj3
Looking for cheaper system than woodhaven mdf door kit or home made ideas for routing face of flat panel cabinet doors.
Hi Jim, welcome to the forum.
With your experience, a couple of pieces of T-track and some strips of 1/2" mdf will get you that for next to nothing.
MDF with poplar frame.
Hi Jim, and welcome to the forum. I think a better option is some 1x3 poplar, a rail and stile set and a raised panel bit. It only takes a few minutes to make a quality, paintable MDF center panel door. This door is just dry fitted and unsanded.
no frame
Hi Jim, and welcome to the forum. I think a better option is some 1x3 poplar, a rail and stile set and a raised panel bit. It only takes a few minutes to make a quality, paintable MDF center panel door. This door is just dry fitted and unsanded.[/QUOTE
Have made many such, but now looking fo:sad:r quicker, cheaper solid mdf doors wih faked stile and rails
I'm confused. Didn't the OP say he was looking to make "flat panel doors" with mdf centers and go cheaper than a door bit set? Poplar would be a good choice for r&s frames, but for tooling flat panel doors... which are along the lines of a Shaker style door.
I'm thinking easiest for him to create a flat panel door would be a Tongue & Groove bit set. Cheapest would be to create the same joints with slot cutters.
I have been making a few doors, but Jim's question has me confused.
Are you wanting to make a one piece door by routing a 3/4 inch piece of mdf?
Or...are you making a flat shaker style door with a flat panel inserted between the rails and stiles?
Or...(insert description here).
I made all of the doors and drawer fronts for our buffet using a raised panel bit for the panels and a cope and stick bit set for the rails and stiles. They all came out nice.
However, I just completed making a door for a desk that is nothing more than four flat pieces (rails and stiles) with a 3/4 inch groove and tenons for the short pieces. All were made on the table saw using a homemade tenon jig. The flat panel was made from glued up pieces of pine that was planed to 3/8 inch. Then I made a shallow 3/4 inch rabbit on the back side so the panel lip is 1/4 inch thick all around. Everything fits together nicely. It is sanded and ready to stain.
The table saw made it easy to obtain a centered groove by making a pass just off center, then rotating the piece and running it through again. I made a few practice runs until I got the desired width for the groove.
Good luck with your project. I would like to see some pics of your progress.
#13 · (Edited)
