I used one of my plunge routers with a modified circle guide to cut out my 15" sub-woofer mounting holes in 1" thick MDF. That makes a LOT of fine dust, even with a 1/4" cutting bit. I could have gotten away with using a jig saw and circle guide but then I couldn't post it up here lol. Did it in 4 passes/hole.
For multiple, smaller holes (2-5/8" for the new instrument panel on my project car) I bought a Milwaukee hole saw exactly the right size for $12.
Here are some pics (not exactly tutorial style, I think I was afraid to pull the phone out during the dust storm, even though it was outside lol) hope this helps a bit. Need to remember the difference between the center distance from the guide pin to the router bit is NOT going to be the hole size.....need to add the outer radius of the cutting bit.....
Best bet is to secure the piece you're cutting on a solid surface, maybe with some styrofoam underneath the way the track saw guys do it. That may also reduce the dust since it cannot fall below the work area now and be more likely sucked up by the vac above the table.
