Routing Wood Veneer Flush to Pantry
647 Views 7 Replies 5 Participants Last post by  DesertRatTom
Hi All,
I am seeking some assistance with attaching/routing wood veneer to a pantry cabinet. Here is the situation:
  • I am going to install a pantry cabinet, the left side is not flush
  • Plan was to install wood veneer to make it flush so the granite will have a strait edge flush against the pantry rather than a squiggly cut
  • The veneer seems slightly thicker than 1/8" thick, but the gap is 1/4" deep
My plan was to use contact cement on both pieces and then route the edge smooth with my new Milwaukee portable router and flush bit. Two issues with this:
1) The back of the cabinet (where I would rest the bearing of the bit) is not flush. I am thinking here to put double sided tape with an appropriate thickness wood to make it flush so I can have a good edge to rest the bearing - thoughts?
2) Even with the veneer the cabinet will not be flush. I am thinking to get just regular unfinished veneer, then put the finished veneer on top - thoughts?
I will take my caliper and measure the veneer but it looks just a hair thicker than 1/8" on my combination square. Last thing I want to do is create the opposite problem (veneer sticking proud of the cabinet).
Below are some pics to help frame the discussion. Thanks for your input!
Design with pantry in question on the right:
Window Cabinetry Shelving Fixture Wood
Here's the gap - goal is to even that so the granite sits flush:
Netbook Wood Table Rectangle Automotive design
This is the veneer panel. Seems slightly thicker than 1/8":
Hood Automotive design Wood Rectangle Flooring
1 - 8 of 8 Posts
G'day @spta97 , welcome to the forum...
Welcome to the forum.
Hi and welcome. Looking at the pictures really helps. I have a different suggestion. How about cutting a stile or crosspiece, and attaching it to the side of the pantry? That way you can make a clean, straight pass to trim the veneer and it will be flush with the cabinet top next to it. I think it will look better than having a funny shaped lip on the side cabinet top.
You will have to match the finish as close as possible and make sure the cross piece is exactly the right thickness, but that is much simpler that a fiddly counter extension that looks like an afterthought fix.
In fact, I'd place the cross piece an inch or two higher than the counter top and let it show.
Thanks for the reply Tom (and everyone else for the welcomes!). Can you elaborate as I am having difficulty following?
Do you mean attach this cross piece to the front of the cabinet for looks or the back for trimming?
I should note, if I get 1/4" thickness (veneer and 1/8" plywood) that "lip" should then be flush.
Thanks!
I must say that I'm a little confused by what the pictures are of but I think Tom meant something like this:
Rectangle Wood Floor Flooring Tile flooring
Oh wow that is a great idea!
Thanks for illustrating that!
Exactly. It will look reptty normal when done and finished.
1 - 8 of 8 Posts
