1 - 2 of 2 Posts
Discussion Starter #1
Hi
Am about to order a mounting plate for my soon to be constructed RT, and would like some advice on which one might suit my needs best. Initially at least, I'll be using it with a Makita 3612C. I'm new to routing, but prefer to invest in quality equipment that will last and that I can grow into - rather than starting at the bottom and needing to replace it soon after. I'm not going for the high-end of the mounting plates, and would prefer to stay under the US$50 mark.
I've looked at the Rosseau plate which seems to get good reviews - although the 'crown' on it seems unpopular. I've also heard that the rings are a pain to remove. There's also one from MLCS. At this price point, they all seem to be phenolic rather than metal - which I guess is fine.
Ultimately I'd like a plate that doesn't need to be drilled by me, to accept the 3612C. It should be strong enough to support my "tank router" - and having a freehand guide pin will probably prove useful.
Any advice - particularly from 3612C users - would be much appreciated!
Regards
Matthew
Since the Makita 3612Cs are quite heavy, Aluminum would be the best way to go. Incra, WoodPeckers, Pinnacle, etc would have good options for you. Otherwise, you could ask a machine shop to fabricate you a custom one, as you need to stretch your $50 a bit more to get a good insert.
1 - 2 of 2 Posts
