I picked up a Ryobi RTS21G Table saw curbside. I had to buy some of the accessories and the motor bearings were shot.
I pulled the motor and replaced all bearings, arbor and the brushes and it sounds great!
However, I neglected to document EXACTLY how the motor is mounted.
I have it all back together but when I try to turn the crank to raise and lower the motor, it binds up and doesn't do anything.
I started with everything cranked down and that definitely didn't work. Then I loosened up different parts but I still can't get to a point where it smoothly raises and lowers. Maybe this was broken when I picked it up but I also don't recall it not working.
Does anyone have one of these and able to tell me how the mechanism is supposed to work?
The pull rod screws are circled in orange, the motor screws are light blue and the support plate screw is circled in green.
Are the motor screws supposed to slide in the slots?
