hello,
Recently I purchased a Lokbox Router Jig for installing fin boxes into fibreglass surfboards
The templates that come with the jig require a 1/2" diameter cutter to be used within a 5/8" outside diameter metal guide bush that screws into the router base..Consequently the clearance between the cutter blades and the inside of the chromed metal guide bush is probably less than 0.5mm or 0.0197" . I don't have much experience of routers but this seems small enough to be asking for an accident. What do you think?
Mark
PS couldn't get hyperlink to work sorry!
Mark
