Anyone else with this Issue? I've recently noticed that the machine was not cutting straight on one of the axis, but strangely enough it only happens on the pass cutting the bottom of the shape cutting from left to right. Allow me to give a bit more detail, the shape is a rectangle (cutting out on 1/8" acrylic plastic sheet) and is positioned with its long sides horizontally when looking at the board, the initial cut starts at the top right corner then cuts the top of the shape moving to the left, as it starts to cut the bottom line of the rectangle moving right thats when i noticed that particular line is bowed inward and not straight, keep in mind the corner dimensions of the rectangle are spot on after the cut and i've tried this several times with other shapes that have straight lines and it does the same thing ... but only the bottom portion..
My initial troubleshoot was check:
1) Waste Board - no visible obstruction, although the there are some grooves from previous cuts, overall plastic sheet lays relatively flat
2) material sheet is secured to the wasteboard, i don't notice the spindle jogging irregularly at any particular point along the trouble axis described (trying to rule out material moving or spindle somehow moving)
Anyone reading this seen anything similar? or know what might be wrong?
thanks
thanks
