A year, or so, ago I purchased several cans of Olympic Oil- and Water-based "Sanding Sealer" from Lowes during a inventory close-out sale. I've used the stuff on a few pieces and it appears to be similar to Deft brush-on lacquer, producing a soft (no protection), thick, self-leveling surface. The directions on the can aren't real specific, but seem to indicate that the sanding sealer should be applied after staining, but before a final top coat such as polyurethane. In any event, the product does yield a nice deep finish when used with a final coat of polyurethane.
That's all fine, but when I read previous posts on finishing, the discussions usually suggest a process where "sanding sealer" is applied prior to staining. Is that correct? I'm familiar with "pre-stain" conditioners (contents ???) for light and softwoods which help prevent un-even stain patterns, but these products have no build height and basically evaporate in 30 minutes after application.
In short, am I using the sanding sealer in the wrong way? Is it similar to lacquer? What is it?
TTG
TTG
