Shame on you, Ralph! You forgot an important criterion. The motorized lift should be computer controlled.All you need to add is a motorized lift with one of those digital readouts.![]()
Thank you!!!Shame on you, Ralph! You forgot an important criterion. The motorized lift should be computer controlled.
By the way, thanks for the chuckles.
Nice work, Tripp!
Cassandra
I need to support something once in a while on my drill press or band saw which are both higher than table saw, work bench, etc. If your sawhorse will hold up two sheets of ply that should cover anything I would put on them.No, not yet, but did use it as an infeed support for the table saw and must not of tightened one side enough, because it started to droop from two sheets of 3/4 plywood. I share a woodshop with my 82 yr old Father, and he is always telling me I tighten things too much, except for this time!!!!!! Thanks for looking.Tripp
