Scrolling
1879 Views 5 Replies 4 Participants Last post by  bobj3
I do intarsia work with a bandsaw, with success. I recently bought a Dewalt scrollsaw for intarsia. I don't have a lot of experience yet but I can't make a radius cut without getting a buldge in the middle of 3/4" mateial. What am I doing wrong?
1 - 6 of 6 Posts
Hi Milt
I do the same and I'm not a Pro. but what do you mean by "buldge in the middle of 3/4" mateial" ?
The real key is the right blade, but buldge ?
The Pro. on the forum is whitewolft710
Also read the links below
http://www.routerforums.com/wood-scrolling/3077-have-blade-question-whitewolfe710.html
http://www.routerforums.com/wood-scrolling/3309-dewalt-dw788.html
http://www.routerforums.com/wood-scrolling/3087-scrolling.html
Real help with the scroll saw ▼
http://www.mikesworkshop.com/Q&A-FP.htm
Bj :)
Bob n all,
Do you use the angle-cutting method where you cut 2 pieces at one time?
If so, what angle do you use on your bandsaw & what is the blade kerf?
..OOps... I was thinking of Marquetry... :) :)
Intarsia is just cutting small pieces and gluing them together, right? :)
What size blades you using?
Hi Joe
"What size blades you using?"
I'm using all the ones I got from Mike's web site (see his link on the other post and below) I got a sample pack (Assortment Pack ) from him and I have been trying all them out great blades :) some will cut 3/4" walnut just like butter and no sanding needed, Mike knows is stuff about blades .
"Intarsia is just cutting small pieces and gluing them together, right? :)" well yes and no, it's 3D wood art so to speak, here's link to have a look see.
Here's a link to one I'm working on ▼
http://www.routerforums.com/introductions/3268-intarsia.html
The Roberts site is where I got my plans and wonder wheel.
Look see stuff ▼
Judy Gale Roberts Intarsia
http://www.intarsia.com/
http://www.intarsia.com/Raccoon.html
http://www.intarsia.com/WolfIntarsia.html
It's great fun for me and it can be hard work also, it's like craving but a bit easyer just alot of sanding to get the 3D look.
Mike's web site ▼
http://www.mikesworkshop.com/freecaps.htm
Marquetry ▼
http://en.wikipedia.org/wiki/Marquetry
Intarsia ▼
http://en.wikipedia.org/wiki/Intarsia
Bj :)
Joe Lyddon said:
Bob n all,
Blade tension is the key. Stretch that puppy out until you think you've got it, then stretch it a little more. You may break a few blades at first, but you'll find the sweet spot.
Also, Flying Dutchman blades are a great help in my humble opinion. You can find a supplier using your search engine or go to
http://www.mikesworkshop.com/blades.htm
Hope this helps,
That's true Doug, that's what's neat about the DeWalt Dw788 it will put it to the max or to say #5 torq. and keep it at that when the blade gets a bit hot or a old one from using it all the time.
http://www.mikesworkshop.com/DaveG.htm#Blade Tension
Bj :)
Hope this helps,
1 - 6 of 6 Posts
